Google index Mobil Theme problem
I set up a mobile theme But webpage and mobil is looks different on google. Can you tell me reason for this issue.
https://webcache.googleusercontent.com/search?q=cache:PAc9oQlY-t0J:https://www.denkbilgi.com/+&cd=1&hl=tr&ct=clnk&gl=tr
From what I can see the mobile theme is displayed on desktop as well. In almost all cases this is caused by caching plugins.
We tested the mobile theme plugin only with the WP Super Cache with which it works properly
https://forum.tagdiv.com/cache-plugin-install-and-configure/
It could work with other caching plugins, with some it may not. So the first thing to check is the caching plugin you use.
but the problem does not improve.
new wp super cache
https://prnt.sc/m1swxd
Seems to work fine at the moment – http://prntscr.com/m2jimm
http://prntscr.com/m2jipnhttp://prntscr.com/m2jis7
I checked with a mobile phone, the mobile theme loads alright, while not affecting the desktop version. I believe you solved the issue.
