Google index problems – ?tdb_action=tdb_ajax
why some of my sites have this domain ending – ?tdb_action=tdb_ajax
Here a link for example
https://www.frisuren-magazin.de/trend-long-bob/?tdb_action=tdb_ajax
it does not shown the site complet without the ending (?tdb_action=tdb_ajax)
How can i fix it?
That is related to the infinite loading functionality. But how would users reach those URLs without adding the parameters in the link? I browsed the website, seems fine. Are there any actual errors created by this?
I am using tech news demo and activated autoload feature.
While looking at the analytic data I found a real-time visitor comes to one of my post ending with ?tdb_action=tdb_ajax
I wonder how he/she reach this URL?
Tried to access the URL with ?tdb_action=tdb_ajax and found, it has no header,footer and page was also not scrolling, and in the source of the page, it has two meta robots tags.
I don’t know what is it and how to fix it.
It is similar like – https://demo.tagdiv.com/newspaper_tech_news_pro/2019/05/13/td-post-hands-on-google-pixel-3a-xl-review/?tdb_action=tdb_ajax
Please investigate it.
Hello @lalit!
First of all please make sure you have the latest version of the theme(11.3.2) and plugins.
So, if you deactivate the autoload feature, then the issue is still there or not?
Please provide some screenshots with the error appearing and many information as you can or a video.
Ok i have the same problem. Google disabled my adsense for some reason because of this particular link:
http://playsiders.com/i-microstrategy-kanei-to-tetarto-megalytero-stoichima-tis-sto-bitcoin/?tdb_action=tdb_ajax
Can’t this be fixed?
In our theme we have a setting when you edit the post template with TagDiv Composer. You need to disable that setting like this: https://www.screencast.com/t/JaSHpq10Y
Let me know the results!
I deleted the Infinite Scroll function and deactivated the cloud template, as it unfortunately had a negative effect on the individual pages.
Unfortunately, I now have thousands of error messages like this:
https://www.ratgeber-haus-garten.com/wp-json/oembed/1.0/embed?url=https://www.ratgeber-haus-garten.com/bambusdielen-als-robuster-terrassenbelag/
https://www.ratgeber-haus-garten.com/wp-json/oembed/1.0/embed?url=https://www.ratgeber-haus-garten.com/rosa-deko-romantische-einrichtungsideen/
How can I delete these pages?
Should I also delete the cloud template plugin from you, also?
Thanks for Help…
Best regrads,
Jan
Hello Jan!
Can you please provide more information about these pages and where exactly the issue is?
Hi Bettina,
thank you very much for your attention.
I don’t know why these pages are generated as described above.
“ubersuggest” shows me these pages as SEO errors and I understandably don’t want these pages either.
I also brought it to your attention last year but it seems Tagdiv team is unable to fix it.
Though, the same issue is with the official newspaper demo pages. Ex: https://demo.tagdiv.com/newspaper_tech_news_pro/2019/05/13/td-post-hands-on-google-pixel-3a-xl-review/?tdb_action=tdb_ajax
If you can’t believe it, check the above URL.
After loading the page, it will also disable the scroll bar and freeze the page completely.
That’s why I had switched to another theme and removed the newspaper theme entirely from my website.
We would like to investigate this issue further.
Please contact us via email at contact@tagdiv.com and provide once again the following:
– admin url and credentials
– cpanel url and credentials
Our team will take a look and let you know what can be done!
Hello
As I said many times before that this issue is from your side not any individual site or theme package.
Many people are posting threats on it so it can not belong to some limited sites.
Why do you need someone’s – admin url and credentials, – cpanel url and credentials and – a link to this topic in order to identify you when it is clearly showing problem on your demo theme?
Discover here: – https://demo.tagdiv.com/newspaper_tech_news_pro/2019/05/13/td-post-hands-on-google-pixel-3a-xl-review/?tdb_action=tdb_ajax
You should fix it from your end, in your original theme package.
You should ask your developers to investigate the bug and fix the theme.
English is not my native language but still, I am trying to describe the issue.
I hope you will understand and fix the issue asap and will not ask anyone to share their site’s login credentials because this issue from your product ?
The year 2024 has already arrived, and the problem that existed in 2019 has not been solved.
If endless loading is enabled, the template starts creating pages with the address: ?tdb_action=tdb_ajax
Okay, pages can be blocked from indexing in robots.txt by adding Disallow: *?tdb_action=tdb_ajax
But why are there two meta tags:
<meta name=’robots’ content=’index, follow, max-image-preview:large, max-snippet:-1, max-video-preview:-1′ />
<meta name=”robots” content=”noindex, nofollow” />
Are you not going to solve this problem at all?
They have been writing to you about this since 2019, but there is still no solution.
Hello Aleksey Petrov,
The URLs with extra parameters at the end aren’t supposed to be clicked directly. They’re part of the automatic content loading feature (infinite loading articles). The theme code ensures search engines ignore them https://prnt.sc/agAGVpavNWrr, and they won’t show up in analytics because they’re not meant for regular users to access directly.
Viewing 14 posts - 1 through 14 (of 14 total)
