Google speed insights, how to fix it
Hi i am trying to get a better perform on the website but this keeps coming up
“Eliminate blocking JavaScript and CSS display the contents of the upper half of the page newsmag” I know the speed booster should do this authomatically, i´ve already check and is activated but seems not working.
Also do you recommend something to minify css and java i´ve tried some plugins but all have issues like loosing complete format, images not showing even though i change some options to stop that to happen.
Thanks for the help
site url: http://www.tierrapermanente.com
See my sticky post on how to minify CSS and JS files manually — from my optimization guide.
To add elements to the speedbooster plugin to move to bottom, read the docs for that (advanced), right side of page.
Thanks Chris!
@paty0323
Please check our Chris’s tutorial here: https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/ and our page speed guide here: https://forum.tagdiv.com/how-to-make-the-site-faster/ (see the 5.2 section for instructions on how to move js/css resources to the footer using the speed booster plugin: http://screencast.com/t/d63V6yZlqgJc ).
