I´m currently installed the Magazine PRO and added a own category with subcategories to my menu. I then added a new article inside the subcategorie. However it didn´t appear on the website when I use the menu. The article is published and also not restricted. What did I miss here?!?
Please check our documentation: https://forum.tagdiv.com/mega-menu/
If you do not mean this, then please provide more information about your issues, screenshots or a video, and your website link, so I can help you efficiently.
unfortunately not … I have setup a Category called Main and subcategories Sub1, Sub2, Sub3. They all show up in the menu.
In each sub I have added two test postings (sub1posting1, sub1posting2, …)
However when I open the menu and open Main -> Sub1 none of the postings are shown there
Here are some related Screenshots:
https://www.screencast.com/t/GrhSQ1vh
https://www.screencast.com/t/gNTqdLjp
https://www.screencast.com/t/wjqi5ybGMxaD
Yes, because the main has 0 https://prnt.sc/6ROKV6WTEEcY, so normally it should display no posts in the frontend.
You should edit the posts from all subcategories and also assign to them the parent “main” category.
That would be ok for the “Home > Main” section… this could show all elements. But inside the “Home > Main > sub1” I would like to see only elements from the sub1 category and not a mix. I thought the reason from categories it so separate elements here ;-).
For example if I have a main category “furniture” and a subcategory tables and another one chairs, I would like to have the option that the user can see all articles for chairs inside the “chair” category and not a mix between chairs and tables.
For example, if you have the main category “furniture”, subcategory “tables” and “chairs”, then you should set the parent category furniture and the child category tables for the posts about tables and set the parent category furniture and the child category chairs for the posts about chairs.
Then you can filter by the child category as normal.
Ok, adjusted the content as seen below:
https://www.screencast.com/t/AHqeurou4FX
https://www.screencast.com/t/keBhlk0SO7
https://www.screencast.com/t/0ji87TtQt4IS
https://www.screencast.com/t/35PZeKIy2Z4
However the website still do not show any articles here…
This reply was modified 4 years by
BastianF.
Let the offset field empty with no space, no value and see the results: https://www.screencast.com/t/peVbVmUDE. For more information about offset feature, please check this tutorial: https://forum.tagdiv.com/offset-feature/.
