Have problem after turn retina setting on
Demo: https://thich.com
After I turn retina setting on, I was using plugin to regenerate the thumbnails too. I already clean up browser cache.
Images are smaller then div block
https://imgur.com/a/msUYx
And images are not showing the same size, even they are same block.
https://imgur.com/a/eDoCO
And homepage latest articles ( at bottom website ), I am using m16, and the images are not clear at all. its blurry, i see it using 150×150 size.
Thanks you
  • This topic was modified 8 years by nhatkymua.
I have inspected the website, there is no problem with the thumbnails from what I can see
– https://www.screencast.com/t/s7FxAG2cFMzN
The latest articles is using module 16 at the moment on your website. Module 16 uses thumbnail size for the image
– https://forum.tagdiv.com/theme-thumbs/
Thumbnail size by default is this one (created by WordPress)
– https://www.screencast.com/t/HsWHH39vSgI0
There are many modules to choose from and use for the latest articles section, you can try a different one
– https://www.screencast.com/t/phzKSY46J
i dont know, please check it this video sreen
https://drive.google.com/file/d/16PdvVAYVprAaKbGZ02ykkzoXdTGbc_Tu/view
I am using 14 inch screen laptop
