Have problem with processes in my theme
I have problem with my theme in my hosting cpanel sometimes I have 100% processes but I don’t have over 50 real time visitors. Please can you tell me how I reslove this problem.
My cpanel statistics now
Disk Usage
15.57 GB / 20 GB (77.84%)
File Usage
178,041 / 350,000 (50.87%)
Number Of Processes
80 / 80 (100%)
Physical Memory Usage
242 MB / 3 GB (7.88%)
MySQL® Disk Usage
192.23 MB / 4.62 GB (4.06%)
CPU Usage
1 / 100 (1%)
PostgreSQL Disk Usage
0 bytes / 4.43 GB (0%)
Bandwidth
606.72 GB / ∞
Any help?
Hello !
Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin.
Let us know the results.
