From the Screenshots:
https://www.screencast.com/t/EokIFScK
https://www.screencast.com/t/vQDPXnnxm
I am having problems customizing the mobile theme,
the header doesn’t have my logo, although I added it in the mobile theme settings on the theme panel.
The featured images for each post aren’t displaying.
On the footer, there is the footer and the sub-footer. On the main footer, there is an “about us” text, which isn’t a button and can’t be clicked, is there any way to delete the “about us”?
This is for my site: valorvortech.com
This is just for the mobile theme for my site, I screenshotted it through a mobile emulator, but the same problem can be seen on all mobile devices.
The content within each blog post is fine and as-needed, however the homepage looks empty and terrible, please advise me on how to properly customize the problems stated above, thanks.
I just checked your website and now you are no longer using the mobile theme plugin.
If you still want to use the mobile theme plugin make sure that you have enabled the mobile theme thumbs -> https://i.imgur.com/xvwyMQx.png also make sure that you do not have a plugin conflict.
The logo and mobile menu can be set from here -> https://i.imgur.com/xkSQysk.png also the about us section can be set from here -> https://i.imgur.com/e2hkXRO.png or remove with custom css.
If you are using the mobile theme plugin, you’ll gain a better speed then responsive version of theme, but in order to achieve that speed you’ll need to create a new content for pages because in the most of cases those were made with builders ( tagDiv Composer, WPBakery ) and you need to use only the mobile editor ( you need to set the content for pages in mobile editor and this content will be display on mobile theme)
-> https://i.imgur.com/9d0UWLT.png
Also you can show the responsive version on mobile theme -> https://i.imgur.com/m0bVB5T.png you can check more details about mobile theme in our documentation -> https://forum.tagdiv.com/the-mobile-theme/ or if you want to have the responsive version only, you can use the amp option from mobile theme -> https://i.imgur.com/oofST3D.png (to use the mobile theme template on amp) or you can disable the plugin.
