Having problems setting the Subscription and Newsletter
I don’t know where to find a link or something for people to subscribe and theres a Newsletter plugin but can’t find anything about that please help.
Here is the guide to set up the Newsletter Plugin https://forum.tagdiv.com/the-newsletter-plugin/
I really can’t understand this can i get some help or pay you to set this up i am really in need of this.
Leonard
Our newsletter plugin is simply a container in which you can place the form code provided to you or which you created by a newsletter service. That code can be entered in our plugin
https://www.screencast.com/t/TpEacPcJ5xaY
I widely used service is Mailchimp, you could give that a try. Check their documentation as to how to create forms
https://mailchimp.com/help/add-a-signup-form-to-your-website/
Thanks i get it done now the only problem i have now is when post to Twitter no image showing and 2 setting up the feed to import news.
For social sharing and general SEO we recommend the Yoast SEO plugin. Install and activate the Open Graph data
https://forum.tagdiv.com/facebook-share/
For Twitter you can set up cards, more about that here
https://www.wpbeginner.com/wp-tutorials/how-to-add-twitter-cards-in-wordpress/
https://kb.yoast.com/kb/setting-up-twitter-cards-in-wordpress-seo/
https://yoast.com/twitter-cards/
For the feed the theme does not have any actual settings, also there were’t many tests conducted. The theme and theme blocks/grids and other elements are designed to work with and display self published content, not import and display external content.
