Thank you so much. There seems a lot of errors. Perhaps because I uninstalled and installed again twice due to my Issue with Google who restricted my site URL (Perhaps the errors caused by the installing of too many plugins and Ad codes place incorrectly…) hours before I sent you a message for help, I had disabled your Theme and some plugins via SFTP FileZilla (During restriction, not allowed to access normally that’s why… After that, I cleared files, Caches… And reinstall Your Newspaper Theme and plugins… I didn’t check widget before the disabling of the Theme… But after reinstalling, I checked the widget and it was locked, grey out and when I tried to edit Theme with the TD editor, I couldn’t scroll down the whole theme (stick at half of the theme)… Is this error? Also I watched all the video tutorials on your web page and Youtube still cannot find a way to show Header Ad on Mobile and 2 more ads placement on homepage do not show up or I can’t find where to place them in Theme panel… If you scroll down on my home page realspill.news you will see no ads pop up ( I can’t find how to place ads on those placement)…. Sorry for this long complicated response.
I haven’t installed tagDiv Mobile Theme plugin yet… I wanted a Header Ad showing on Mobile devices. So do I need to install this tagDiv Mobile Theme plugin or not?
I was getting stuck the whole night.
Thank you for guiding me
The theme has 2 different headers, one for desktop and one for mobile, so you can use tagDiv Composer edit the website – https://i.imgur.com/hdQvNx2.png – https://i.imgur.com/761rSUg.png to set an ad on the mobile header, use the mobile viewport and add the ad box in the place you’d like to be (just check to be on header one – https://i.imgur.com/EHiF1SD.png
For the problem with tagDiv Composer, could you provide some more details? Some screenshots or a short video?
Thank you so much.
Here all the screenshots of the problems I am facing.
Kindly check: https://drive.google.com/drive/folders/1YpCVYJSvz19LPV-GSeHkItAWZxjlaPhv?usp=sharing
I don’t know how to send, that’s Google Drive.
Especially, the scroll part… Have no idea why I can’t scroll.
Looking to hear from you
I understand that you’ve installed the Default PRO pre-built website, correct? If so, it can be edited on the frontend using tagDiv Composer. Please try testing with only the theme’s required plugins enabled and check whether the scrolling issue in Composer still occurs. Under normal circumstances, you should be able to scroll down with your mouse without any problems.
The ads are managed through tagDiv Composer using the Ad Box element, so they can be removed or added from the Theme Builder with the same Ad Box element.
Additionally, the Theme Panel includes global ad sections. You can configure your ads there and then use the Ad Box element to display the ads you’ve set in the Theme Panel:
https://i.imgur.com/Oac1GHY.png
Regarding widgets, they are displayed using the newer Widgets system, but most users still prefer the Classic Widgets. The theme is now primarily built with elements created in tagDiv Composer, which can be edited directly on the frontend. However, if you prefer to use widgets, you can add them to a page and/or template by using the Widgets element available in tagDiv Composer.
