Header and footer problem Influencer
I’m using Influencer template.
I have problems with footer. It often breaks, and after several reloads it load corectly. Hm, wierd situation. Also, above main menu I have white space and I dont have an idea how to remove it. Thank for the answer.
Hello !
Please provide a link to your website so we can take a look.
Hello, thanks for the answer. Is there some private area for link provide? Thanks
Hello !
– admin url and credentials
Our team will take a look !
Hello, mail was sent last night. Thanks
Hello, I have lot of issues with Newspaper theme. Category pages crashes, footer also. Hm, I sent you email with screenshots. Could you please inspect the issues and give me right directions what to do.
We received your email and we’ll try to check all these problems as soon as possible, unfortunately at the moment the support is a bit crowded so an answer is expected between 24-48hrs.
Thanks. I’ve sent you Cpanel credentials via email also. I have another problem with tagDiv composer. Error: Error at rows: 5(models) : 7(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
Hi renato100, we’ll check this problem via email too.
We have a quid for what you can do when you get this problem with tagDiv Composer -> https://forum.tagdiv.com/tagdiv-composer-not-working/
