Header and Footer Problem ! Please Solve This Problem !
Hi, i’m Downloaded Header Template from Cloud library, after downloaded The template and i’m tried to edit my theme showing error in header, and same as footer also,
See This Attachment : Image 1 , Image 2
and second Problem When I Try to save Template the page not saving the saving button spin continuously
Attachment : Attachment
Warning: getimagesize(): https:// wrapper is disabled in the server configuration by allow_url_fopen=0 in /home/username/public_html/wp-content/plugins/td-cloud-library/shortcodes/header/tdb_header_logo.php on line 792
Warning: getimagesize(https://www.somedomain.in/wp-content/uploads/2020/08/2020032112ad65c1-fbc9-09ef-3255-7329fc32684e.png): failed to open stream: no suitable wrapper could be found in /home/username/public_html/wp-content/plugins/td-cloud-library/shortcodes/header/tdb_header_logo.php on line 792
Hello !
For Warning: getimagesize, please make sure that all the settings are like in our requirements, please follow the guide carefully
Please enable the option in PHP.Ini as you can see here: https://stackoverflow.com/questions/37531149/php-getimagesize-not-working-on-external-links That allow url is 0 on your side.
Thank you
