Hey. It does not have front-end. Only backend editor. At least this one that comes within theme.
From expirience I can tell you that backend visual composer editor is much better and much more precise then frontend. You will see that it is much easier to edit things in backend.
I have multiple themes that came with visual composer, and I have visual composer alone purchased from envato, and whenever I do stuff with it I do it in backend.
Many thanks for the response. I was trying to edit the demo… figured out I had to create a new page.
Can you answer this question…
Can I edit the contents of the Grids or Blocks?
I want to keep the design but not the type of content in each section. I do not want everything to be a post. I would like some sections of the grid/block to be just an image with a link to another page.
Big Grid 3 has a 4 panel layout, if I wanted 2 of these to be something other than a post how do i do that.
You can apply a redirect to your links using a redirect plugin (301 redirects)
Blocks can also show events (if you have an event plugin) or pages.
You can read more about block settings here: https://forum.tagdiv.com/block-settings-tutorial/
