Help
Please make sure that you updated the theme according with our documentation: https://forum.tagdiv.com/how-to-update-the-theme-2/ deactivate all plugins and also you update the plugins included in theme path Newspaper-tf\plugins clear all caches and test again.
If you use child theme for files customizations it’s a good practice to check update_log.txt file for each update and see what files had been modified so if those specific files are used in the child theme you will have to check your customizations to not break the functionality of the theme.
It’s nothing. The problem is:
wp buster
Do transfer only folder wp buster before uploading
  • This reply was modified 10 years by Koznazna.
Glad you figured it out!
I threw the whole folder wp buster and put the others out of the darkness, and the same case.
I’ll backup before update
I can not make it. Do you have any idea?
See: http://www.koznazna.com
I returned all prior updates.
Well your website displays properly now and i could not see any errors so i assume it’s ok now. Please let us know if you need further assistance.
Thank you,
I returned the themes of the site and the base 24 hours earlier.
He disappeared right sidebar on all sides? I did nothing in the settings.
This is so startling after the latest corrections this theme. Everyone advise against throwing latest updates threads.
And still I can not find why it does not appear the right sidebar on posts …
Please make sure you update the theme to the latest version and try to disable all plugins except visual composer, clear your cache and reset CDN if you use it. Plugins could interfere with the sidebars. Also check your widgets area and see if you have any widgets set to your sidebar.
Let us know how it goes.
thank you,
Problem solved. The widgets were all empty. I had them again belting.
