HELP
See for yourself 3narratives.com – I deactivated just about every single plugin to ensure I woulndt have conflict, I re-installed the theme and nothing has worked. Have spent an entire day trying to figure it out. HELP
I removed every single plugin and re-installed the theme with the recommended plugins, and I now see that the tagDiv plugins aren’t working inside my CMS all I see is code, I don’t have access to work with the pages. Please help
If you see only code, is because a demo from the theme has been installed and one of the theme plugins (tagDiv Composer, tagdiv Cloud Library) are disabled now.
The pages and cloud template scan be edited using tagDiv Composer, which is the theme builder and can be used to edit/create pages and templates (not articles)
