page names and post names cannot be the same so
a page cannot be “how to contact us” and a post “how to contact us” at same time
pages don’t appear in categories, only posts
Not sure if that helps. Probably TagDiv will need more information to help you.
(I don’t work here…)
Hi @rida
You can use blocks to sort posts from each page. For example in page 1 you add block 1 and choose in filters category1; http://screencast.com/t/BzaQQ74DhD9e For page 2 you can do the same, just change the category: http://screencast.com/t/8PwvC4KCIz2 You can also use page-builder+latest as a page template and choose the category from post loop settings: http://screencast.com/t/F2b8jkN9LXy
For more details about how to use visual Composer and how to built pages please check these links: https://forum.tagdiv.com/newsmag-how-to-use-visual-composer/ – https://forum.tagdiv.com/newsmag-block-settings-tutorial/ – https://forum.tagdiv.com/newsmag-homepage-how-to-build-and-set-it/ – https://forum.tagdiv.com/newsmag-page-templates/
Hope this helps.
