I want to redesign the Menu Alignment like the Attached Image, How can I do it? Can you please give me Instructions and Code?
Alignment should be Center. How can I do it? Please give me the code and Instruction, how to make this.
I need it urgently.
There are multiple header styles to choose from
– https://forum.tagdiv.com/header-styles/
Choose the one you like, if you want to modify something about the header please provide a link to your website. I can provide you with a code to center the menu items but it may not work for you. It is easier to inspect your website before.
