Help, Garden Pro theme demo
How do I place the ads? I had tried, but they did not show on the website
Your theme is not showing on mobile, What do I most do?
Hello @seolatino !
In the cloud templates, you can add the ads when you edit the post with TagDiv Composer in the element called ” Single Post Content ” in the tab ADS. Documentation here: https://forum.tagdiv.com/article-ads/
Or you can use the element called “Ad box” from TagDiv Composer and there you need to add the ads: https://forum.tagdiv.com/ads-adsense-overview/
If you want to use auto ads(are displaying randomly in your website), then they should be placed in the Theme Panel -> Analytics/Js Codes.
