I added the COVID Stats counter and the TagDiv Composer got stuck and after it was back, half of my home page is missing. When I tried to design it again by adding row or element, I am getting the following message.
_getDestinationModel Error: Container destination not available! Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
_getDestinationModel Error: Model id of the container destination not in data! Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
Tried to undo but still no luck. Please help urgently.
This did not sort out. I restored the website from backup. Though I lost some posts, my home page is back.
Please make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
