Hi TagDiv
Is there any way to make a post stay at the top of the page even after newer posts are added??
For example for my news site there may be an event in the world that is the most important for 2 or 3 days and the post that I make on it I want it to stay at the top even after I add new posts.
This will be very important for my news site so please let me know how I can do this
Thanks in advance
In order to make posts stay inside a particular block, you will have to create separate blocks. One with the posts you want sticky and one with the latest posts. You cannot have both sticky posts and dynamic ones inside the same block element. You can use either the featured posts option: https://forum.tagdiv.com/featured-posts-2/ or the post id filter from the block settings: https://forum.tagdiv.com/block-settings-guide/
