Help, I met a very headache thing …
That’s it. In China, the government has a firewall, but my computer has been using Shadowsocks. Now I changed the template, but I turned off Shadowsocks and found that all the images were not displayed (even though they all have servers) and the Share button does not show …
All this back to normal after I opened Shadowsocks, why?
My test address is: test.qdzmgj.com
The address you open should be normal, but I do not have access to Shadowsocks in the country if there is no way to display pictures and share button.
I’m not sure what you mean. Your site images seem to display just fine. What images are not showing up without shadowsocks ? I recommend disabling all plugins except the page builder, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
tagDiv Speed Booster
Hello, all because of this plug-in caused. If I do not install this plug-in in addition to the speed of what will be the impact?
Hello sir.
I still have a question you want to ask, I use the weather widget, and the normal display. But can this widget show the local weather based on the visitor’s IP? Or it can only be a fixed display of a city’s weather?
hey Weather city can not change it?
No.
https://forum.tagdiv.com/topic/top-bar-weather/
Also read this manual: https://forum.tagdiv.com/weather-widget/
thank you!
