Hello everyone,
I’m using the Newspaper Default Pro theme for my website, http://www.sydneyfocus.com, and I’ve encountered an issue with the homepage layout that I need help resolving.
Issue Description:
On my homepage, there are several sections with headings like “Don’t Miss,” “House Design,” “WRX RACING” etc., which are automatically populated with articles and are completely irrelevant to the categories and tags I have set up. They are nowhere to be found in the Bluehost categories/tags I’ve created, The articles displayed under these headings are often mislabeled or not relevant to the heading itself. For example, an article about local bushfires appears under “Make it Modern,” which is misleading and inappropriate.
What I Need help with:
I’m looking to adjust these sections so that they either display the correct articles relevant to their headings or remove/change these headings to better reflect the content being displayed.
What I’ve Tried:
-I’ve checked and correctly categorized my posts.
-I’ve explored the theme settings, including Template Settings, Block Settings, and Post Settings, but haven’t found a way to adjust these specific homepage sections.
-The categories are well-curated, and the issue seems to be with how the homepage pulls and displays these articles.
My Question:
How can I modify these specific sections/headings on my homepage to ensure they display the correct content? Is there a setting in the Newspaper Default Pro theme that allows me to control which articles appear under these headings, or a way to customize these headings to align with the content displayed?
Any guidance, tips, or step-by-step instructions would be greatly appreciated, as I’m relatively new to this theme and want to ensure my site is as user-friendly and accurate as possible.
Thank you in advance for your help!
Best regards,
Jordy
Hello Jordy,
The titles are not related to the category because there are set manually, you need to edit with tagdiv Composer, select the element and change the title -> https://i.imgur.com/Erd8lbG.png -> https://i.imgur.com/pGEWg5z.png
Also, you can apply filters on the blocks -> https://forum.tagdiv.com/flex-block-settings-guide/
Here is a video that will show you how to use the builder to create a website from scratch https://www.youtube.com/watch?v=SoGQ0d5kIBg to do this you’ll need to already have the posts.
Also, on our channel https://www.youtube.com/channel/UCOT1RiNysIPCTPSnVZskwtQ, you can find more videos that can help you and documentation https://forum.tagdiv.com/newspaper-theme-documentation/ and you can ask us here on the forum or email if you have any questions.
