Hello PAltish,
If you are using the Mobile Theme for your mobile mode, please notice that this concept is a bit of different by the Default General Responsive Mobile mode. The mobile theme does not recognize the Visual Composer shortcodes, and that’s why mobile theme does not load the Trending Now and Big Grig 8. This is the theme behaviour with this kind of the plugin and if you want to change the structure of this you should try to develop the plugin and implement as you like in it. For more information about this plugin, please check the documentation here -> https://forum.tagdiv.com/the-mobile-theme/
