The problem: we are trying to insert the a code to implement a third-party advertisement system based on Google Tag. This code is to coexist with current Ad Sense ads.
We have tried from multiple places to have it “live” on our webiste, unsuccessfully.
Places we tried:
– the slot included in the template
– template’s header.php directly from theme’s root
– template’s header.php directly from a Newspaper child folder.
Here are our conclusions:
You can post content within the header.php, and we can see it live in production environment, i.e. general comments or random text. However, the previously mention code does not update.
Here the steps we did.
1st. We enter the theme folder by FTP and then create a child.
2nd. We create a header.php with the modifications we needed.
3rd. we purged in wordpress
4th. we review the changes.
nothing happened.
We did this process repeatedly and the changes we made to “header.php” were not reflected.
then:
we made a backup of “header.php”
We put the changes in a dummy copy of the “header.php”.
We purge
The changes did not take effect.
then:
We eliminated the “header.php” that we were working on, to see if the changes actually took effect. We purged. On the page, the header disappeared. We retrieve the original “header.php”. Then purged. The page header appeared again.
These steps are carried out repeatedly.
In addition, we tried to create a log in the console and we could not see it either, meaning there was no error logging for none of the above steps.
Using our theme the ads can be set using theme panel for standard post templates, or using tagDiv Composer and ad box element for pages and cloud template.
Also if you are using a child theme, you’ll need to make sure that is set as in our guide from here -> https://forum.tagdiv.com/the-child-theme-support-tutorial/ -> https://i.imgur.com/M8keBKF.png also in theme panel there is a place where you can set the code and this will be set in head of the website -> https://i.imgur.com/alhiNmD.png
One last thing, make sure that your ads are approved, if these are not yet approved it will not appear.
