FIXED! When not logged in, the site shows random posts and not the theme
UPDATE: I had to set a posts page in the TagDiv composer. When unset, it logged a page I don’t know where it pulling from.
Hi I am attempting to use this theme and when not logged in it doesn’t look right or work.
This is on desktop.
What Logged out sees: Wrong site
What logged in sees: Correct version of home page
http://questsandchaos.com
Usually, this happens with cache plugins. If the cache plugin does not have mobile support then the mobile theme version can be delivered instead.
The solution would be to use the recommended WP Super Cache plugin instead and activate these settings (especially the mobile device support): https://forum.tagdiv.com/cache-plugin-install-and-configure/
I hope this helps.
