Help with mega menu – hiding sub-sub categories
Hey Guys – I wonder if you can help me. I have a website using the theme Newspaper – it has a great mega menu facility for this news based website. The only issue I have is that on one drop down menu I have an A-Z Directory set up – I do not want it to display every sub-sub category if that makes sense? They are all housed under ‘Clubs’. Is there a way to hide the sub sub category through CSS as I have gone through the theme with a tooth comb and there isn’t a ‘switch off’ option for this. I attach some snapshots 1) The megamenu as it looks now 2) What I want to hide and 3) A snapshot of the menu. Would love some advice
That is a mega menu with sub-categories -> https://forum.tagdiv.com/mega-menu/ what you can do is to display only the first sub-category -> https://i.imgur.com/1TJkyqy.png
Hope this will help you!
I use you babyblog theme for elenaculacenco.ro blog.
My Issue: Mobile Megamenu did not work properly. Works Only mobile menu links with no submeniu. Please check mobile version of elenaculacenco.ro .
Details:
Butons like “Acasa”, “Recenzii”, “Despre mine”with no submenus works fine, the pages are open. But, if I use other megamenu mobile buttons (red / black menu background) nothing open.
I can find in wp-admin, Newspaper, Theme panel, options to fix this.
Please help me fix this:
I want all the megamenu buttons in the mobile menu to work like the “Despre mine” button. Regardless mobile website pages, any buttons in megamenu must works like “Despre mine” button.
The mega menu is working only on mobile only if you are using the responsive version, the mobile theme plugin will not recognize the mega menu, therefore you’ll need to make a new menu with the elements you want to have in mobile menu and set it in Newspaper> mobile theme > header > https://i.imgur.com/031qn30.png or you can disable the mobile theme from some post/page using this option -> https://i.imgur.com/AQmgQKb.png
Salut Calin,
Multumesc pentru raspuns.Blogul este in romana, banuiesc ca te-ai uitat. Toate cele 7 post au mobile theme settings disables. Meniul / megameniul este unul nou creat.
Si totusi megameniul mobile nu functioneaza pe butoanele custom link – megameniu ID Category. Doar pe butoanele page si categori.
Am mare nevoie sa rezolv problema asta urgent pentru a publica blogul. E vorba de un punctaj intr-o examinare la Colegiul Psihologilor.
Cred ca imi scapa ceva. Nu prea inteleg cum pot opta pentru “responsive version”. Eu utilizez thema voastra. Poti sa imi explici mai in detaliu ce sa fac?
PS: nu stiu daca undeva in regulamentul forumului este obligatorie limba engleza.
Daca da, scuze anticipat. Am vrut sa elimin poate exprimarea mea defectuoasa in engleza.
Putem vorbi si pe un alt canal? Pot contacta direct colegii din AB?
Astept help asap.
Multumesc,
Alin
Buna Alin,
Normal limba folosita pe forum este limba engleza ca sa ii ajute si pe celalti useri care au probleme similare.
Acum referitor la “problema” cu mega menu, din cate vad eu folositi mobile theme plugin -> https://i.imgur.com/jYy5MLO.png aceasta este o tema conceputa de dezvoltatorii tagdiv peantru a obtine o versiune mai rapida pe dispozitivele mobile. Cand utilizezi acest plugin, aspectul de pe mobil nu va mai fi acelas cu cel de pe desktop, iar unele functionalitati nu sunt recunoscute de catre mobile theme, acesta fiind realizat peantru a mentine versiunea mobila cat mai simpla si rapida. Datorita acestor implementari pentru a avea un meniu functional pe dispozitivele mobile puteti creea un nou meniu ca cel principal, dar in loc the mega menu setati un link catre acea categorie (sau setati direct categoria in menu) apoi setati in theme panel > mobile theme > header > mobile menu meniul creat.
O alta varianta este sa folositi versiunea mobila a temei (versiunea responsive), acest lucru se poate efectua dezactivand mobile theme plugin, folosindul mobile theme doar ca template pentru amp -> https://i.imgur.com/uVuacM3.png sau folosint mobile theme dar si varianta responsive pe anumite pagini sau posturi, acest lucru se poate face folosind optionea pusa in editorul Gutenberg -> https://i.imgur.com/dIiLlJ0.png
Pentru moment putem oferi suport doar pe acest forum si pe email.
Sper ca acest raspuns sa va ajute!
O zi frumoasa!
