• Home
  • Showcase
    • Newspaper Showcase
    • Newsmag Showcase
  • Support
    • Newspaper Forum
    • Newsmag Forum
    • Blog
    • Documentation
      • Newspaper Documentation
      • Newsmag Documentation
      • The Theme API
    • What’s New
      • Newspaper
        • What’s New in v 11.5
        • What’s New in v 11.4.3
        • What’s New in v 11.2
        • What’s New in v 10.4
        • What’s New in v 10.3.7
        • What’s New in v 10.3.2
      • Changelog
        • Newspaper
        • Newsmag
        • tagDiv Opt-In Builder
  • Services
    • Web Development Services
    • Web Solutions & CMS Development
    • Web design & Front-end Development
    • E-Commerce Development Services
    • Page Speed Optimization Services
  • Buy Newspaper
Search
tagDiv support
  • Become a member
  • Sign in
  • Home
  • Showcase
    • Newsmag Showcase
  • Support
    • Newspaper Forum
    • Newsmag Forum
    • Blog
    • Documentation
      • The Theme API
    • What’s New
      • Newspaper
      • Changelog
        • Newspaper
        • Newsmag
  • Services
  • Buy Newspaper
Home Newspaper Help with removing a pop-up sign-up, and adding a replacement
manbodyspirit
#514238
Aug 4, 2024 at 4:27 pm
Hi there,
I’ve spent hours trying to find where in the theme a former team member installed the pop-up form pictured here:
View post on imgur.com
http://www.goodformen.co
I need to remove this, and replace it with a sign-up form for a different email provider.
Can anybody help me find it, or even do the work of finding and replacing it for me please?
Thanks so much.
  • This topic was modified 2 years by manbodyspirit.
Anamaria
#514256
Aug 5, 2024 at 8:08 am
I think that you have malware on the website because I can not access it. Please update to the latest version 12.6.6
If you want to update the theme, you should download the latest version of it from the Theme Forest account and download it.
I recommend that you update the theme manually https://forum.tagdiv.com/how-to-update-the-theme-2/ via FTP/cPanel/File Manager, also if possible disable extra plugins during the theme update to avoid any problems that may arise and make sure that you have activated the tagDiv Standard pack plugin to keep the website’s look. You can try to update the theme on a staging website.
After you update the theme, you need to update the theme plugins too.
In the worst cases, the settings in the theme panel may be lost (there have been isolated cases), in these cases, after the theme plugins that were previously used are activated, you will have to use a backup for the theme panel -> https://forum.tagdiv.com/import-export-theme-settings/
You could consider reinstalling the WordPress version, and checking for this plugin wp-zexit.php. It might be wise to inspect via FTP if it doesn’t appear in the WordPress -> Plugins. Additionally, using Wordfence to scan the website and remove unknown users would be prudent.
Change admin passwords and delete admin accounts you are not familiar with;
– Delete any weird/unknown plugins;
– Delete the weird/unknown themes;
– Clean unfamiliar Theme Panel injected code (example – https://i.imgur.com/4q70kCv.png);
– Clean WordPress files (example – https://i.imgur.com/stJCqiK.png)
Please block /wp-json/tdw/save_css
If an attacker wants to target this URL /wp-json/tdw/save_css they can do so. Even if the website uses a different theme, the attacker can still try that URL. We could add an option to be able to enable/disable the Live CSS, it will be considered. But for now in order to remove it this can only be done with a modification to the composer plugin. I think that all that removing it requires is to comment this line of code – https://prnt.sc/RtwvL5Nc4ikR -> https://prnt.sc/ymZmhdUfp57U But as I mentioned, the attacker can still try to access the URL.
manbodyspirit
Support Hours (GMT+2)
Monday - Friday:
8:00 AM - 17:00 PM
Documentation
  • Newspaper
  • Newsmag
Facebook Instagram Twitter Youtube
Welcome to the Community! This is our main Support Center and, also the place where you can make new friends, people just as passionate about websites as you are. Don’t hesitate to ask for help as we are here for you. Thank you for buying our products!
Contact us: contact@tagdiv.com
  • Home
  • Blog
  • Forums
  • About us
  • Support policy
  • Privacy Policy
© tagdiv.com | Proudly made with by tagDiv. All rights reserved
We use cookies on our website to give you the most relevant experience by remembering your preferences and repeat visits. By clicking “Accept All”, you consent to the use of ALL the cookies. However, you may visit "Cookie Settings" to provide a controlled consent.
Cookie SettingsAccept All
Manage consent
Privacy Overview
This website uses cookies to improve your experience while you navigate through the website. Out of these, the cookies that are categorized as necessary are stored on your browser as they are essential for the working of basic functionalities of the website. We also use third-party cookies that help us analyze and understand how you use this website. These cookies will be stored in your browser only with your consent. You also have the option to opt-out of these cookies. But opting out of some of these cookies may affect your browsing experience.
Necessary
Always Enabled
Necessary cookies are absolutely essential for the website to function properly. These cookies ensure basic functionalities and security features of the website, anonymously.
CookieDurationDescription
cookielawinfo-checkbox-advertisement1 yearThe cookie is set by GDPR cookie consent to record the user consent for the cookies in the category "Advertisement".
cookielawinfo-checkbox-analytics11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Analytics".
cookielawinfo-checkbox-functional11 monthsThe cookie is set by GDPR cookie consent to record the user consent for the cookies in the category "Functional".
cookielawinfo-checkbox-necessary11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookies is used to store the user consent for the cookies in the category "Necessary".
cookielawinfo-checkbox-others11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Other.
cookielawinfo-checkbox-performance11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Performance".
viewed_cookie_policy11 monthsThe cookie is set by the GDPR Cookie Consent plugin and is used to store whether or not user has consented to the use of cookies. It does not store any personal data.
Functional
Functional cookies help to perform certain functionalities like sharing the content of the website on social media platforms, collect feedbacks, and other third-party features.
Performance
Performance cookies are used to understand and analyze the key performance indexes of the website which helps in delivering a better user experience for the visitors.
Analytics
Analytical cookies are used to understand how visitors interact with the website. These cookies help provide information on metrics the number of visitors, bounce rate, traffic source, etc.
_ga2 yearsThis cookie is installed by Google Analytics. The cookie is used to calculate visitor, session, campaign data and keep track of site usage for the site's analytics report. The cookies store information anonymously and assign a randomly generated number to identify unique visitors.
_gat_gtag_UA_43963494_11 minuteThis cookie is set by Google and is used to distinguish users.
_gid1 dayThis cookie is installed by Google Analytics. The cookie is used to store information of how visitors use a website and helps in creating an analytics report of how the website is doing. The data collected including the number visitors, the source where they have come from, and the pages visted in an anonymous form.
Advertisement
Advertisement cookies are used to provide visitors with relevant ads and marketing campaigns. These cookies track visitors across websites and collect information to provide customized ads.
IDE1 year 24 daysUsed by Google DoubleClick and stores information about how the user uses the website and any other advertisement before visiting the website. This is used to present users with ads that are relevant to them according to the user profile.
test_cookie15 minutesThis cookie is set by doubleclick.net. The purpose of the cookie is to determine if the user's browser supports cookies.
VISITOR_INFO1_LIVE5 months 27 daysThis cookie is set by Youtube. Used to track the information of the embedded YouTube videos on a website.
YSCsessionThis cookies is set by Youtube and is used to track the views of embedded videos.
Others
Other uncategorized cookies are those that are being analyzed and have not been classified into a category as yet.
CONSENT16 years 5 months 26 days 13 hours 25 minutesNo description
yt-remote-connected-devicesneverThis cookies is set by Youtube and stores the user's video player preferences using embedded YouTube video.
yt-remote-device-idneverThis cookies is set by Youtube and stores the user's video player preferences using embedded YouTube video.
SAVE & ACCEPT
Powered by CookieYes Logo
