Hi Guys.. Mobile Theme help
Sorry for interrupt your time but i need help with the mobile theme because dont show the look like show on doc and also the header category dont update.
Any help is gonna be very appreciate.
I have inspected your website, and the mobile theme is not displaying at all on your website. Please note that the this might be happening because of a plugin conflict.
You can see if that is that case by deactivating all your plugins except the plugins included in the theme package, and clear any caching installed. Then check if then mobile theme is working.
It could also be the caching plugin that you use. It is recommend to use the WP Super Cache plugin for optimal results
