Hide Element for Guest users on Navigation Menu
Good day, pls I have issues with this;
1. Please I am trying to hide one element on my navigation menu. I want it to show for only logged in users.
i.e. on my website hiideemedia.com, I have a menu login on navigation but I want it to show for logged-in users alone. Only the element not the entire column or row pls.
2. Also I noticed a hidden option on elements (CSS >> Dsiplay section) hide them totally and there is no way to get them back even inside the tagdiv composer. Other builders only show a cross on hidden elements for easy accessible but yours get them hidden for life. Even though I can get it back from the raw code always but it is not ideal.
  • This topic was modified 3 years by hadharm.
Hello @hadharm !
1. Unfortunately, we have no feature like this.
2. This issue has been discussed already here: https://forum.tagdiv.com/topic/post-views-counter-will-not-disable/
Okay, thanks for that. I will check the articles you send. Another issue is; I noticed that the social icons I placed on the navigation menu didn’t open in the new tab.
I have make ensured open in new window is ticked from the social icon element of tagDiv composer.
Pls is there any solution to that??
I checked and there are opened in a new tab -> https://app.screencast.com/cZBSDFhdWBjVm
Apologies for the confusion. It doesn’t open for me in new window as admin but after I tried with other users and incognito it work fine.
Pls I noticed from your video that the screen doesn’t fit full height into your screen.
Did you zoom in because I have set the animation background to be full height with columns to be at middle for wide-screen devices. And it works fine on 15 inch and 14 inch laptop when I tested it.
  • This reply was modified 3 years by hadharm.
Also is there a way to add code inside functions.php from theme panel or other means without editing theme core files so that I won’t have to input the code again after the update???
Yes, was Zoom. You can add in the function.php from the child theme -> https://forum.tagdiv.com/the-child-theme-support-tutorial/
Great got that and it is active. Thanks for that. I hope it doesn’t update anytime there a theme update.
Normally, when you save the code in the child theme is not overwritten on update.
great thanks
