High CPU and Memory Consumption.
Hi all, my friends, my site is showing high CPU consumption on my VPS server, I did some tests deactivating all the plugins, however the consumption continued high leaving the site slow and even knocking down the server.
The other test I did was to disable the theme NEWSPAPER, putting another theme, in this my CPU did not exceed 20%, or the problem is in your theme …
It did all the optimizations that you explain in the manual, however nothing solved … can you the creators of the theme help me or even configure for me? I await your reply as soon as possible ..
Thank you
OBS: I used google translator to communicate with you my language is Portuguese, below this with my original language ..
Alto consumo da CPU e Memoria.
Olá tudo bem, meu amigos, meu site esta apresentando alto consumo na CPU no meu servidor VPS, fiz alguns testes desativando todos os plugins, no entanto o consumo continuou alto deixando o site lento e até mesmo derrubando o servidor.
O outro teste que fiz foi desativar o tema NEWSPAPER, colocando um outro tema, neste a minha CPU não passou de 20%, ou seja o problema esta no tema de vocês…
FIz todas as otimizações que você explicam no manual, no entanto nada resolveu… vocês criadores do tema pode me ajudar ou até mesmo configurar para mim? Aguardo sua reposta o mais breve possível..
Hello padom,
First of all, please make sure that you have respected all the theme’s requirements from here -> https://forum.tagdiv.com/requirements-for-newspaper/
Also, some similar forum topics that you can read for more information
– https://forum.tagdiv.com/topic/theme-causing-high-cpu-usage-2/
– https://forum.tagdiv.com/topic/sql-querys-high-cpu/
– https://forum.tagdiv.com/topic/newspaper-theme-slow-to-respond/
Please notice that the problem is not our theme, you can try with a default theme and check the results, sorry!
Also, if you are unsatisfied with our product and if you want your money back, please make a full refund here -> https://themeforest.net/refund_requests/new and we will get your money back as soon as possible.
So, I did all the procedures, it did not solve … I left the default theme, with the default the server normally flows …
I noticed that what is causing the slowness and widget of recent blog posts ..
What you can do?
Então, eu fiz todos os procedimentos, não resolveu… Deixei o tema padrão, com o padrão o servidor flui normalmente…
Percebi que o que está causando a lentidão e widget dos blocos de posts recentes..
O que pode fazer?
Hello padom,
Unfortunately, this kind of problem does not a theme related, sorry! In this case, your dedicated server plays an important role. Did you have consulted with your hosting provider regarding this problem? They should be able to provide a more accurate response.
the same problem is mentioned in my blog. No problem when using different theme but I would suggest the problem when using your theme.
Theme Status Panel;
https://prnt.sc/lcpdoh
I used translation to contact you
Hello vedatkorkut,
my problem continues, I changed up VPS, Digital Ocean the problem continues, see attached image
Have you try to reduce the cpu and memory consumption by wordpress?
Please read this :
-> https://wordpress.org/support/topic/how-to-fix-wordpress-high-cpu-usage/
-> https://crunchify.com/noticed-higher-cpu-memory-usage-for-wp-site-wordpress-optimization-guide-htaccess-tricks-disqus-problem/
Hope this will help you.
Thanks for your understanding!.
@pandom ; php version 7.2 and try? it will probably be an improvement
//I used translation to contact you
