Hi I have for the following sites
https://www.tenerifecanarie.it/
On the pc the homages are seen well, while on the smartphones you can see the codes. How can I solve the problem?
It seems you are using the Jetpack mobile theme, that will probably not interpret the page builder shortcodes and display the elements.
Deactivate the Jetpack mobile theme and the problem is solved. There is a mobile theme provided in the theme package if you want to use one
– https://forum.tagdiv.com/the-mobile-theme/
