Home Page Displaying Too Many Posts
I have went into WordPress > Settings > Reading and selected home page to only display 10. But it has much more. Screenshot of settings https://ibb.co/fxGx5V4
Is there anyother spot in the dashboard you think that is conflicting? Site is https://minecraft-resourcepacks.com
Hello !
Newspaper themes Demos and Cloud templates are fully editable using the tagDiv Composer. You can set the post limit in your blocks from here: https://www.screencast.com/t/XtEscQ7t9Qt
Hi Vlad! I am just using the recent posts, so i do not have homepage? Am I ot able to control this feature on http://stage.minecraft-resourcepacks.com/
Hello !
If you’re not using Newspaper theme then all the settings come from wordpress. Unfortunately this option cannot be changed from Newspaper settings.
We are sorry for the inconvenience!
Hi Vlad! No worries thanks for the reply. I am using the newspaper theme… do I need to change it to a static page for it to work on the homepage? I like all my recent blog posts to appear as shown above. Thanks!
Hello !
The easiest way to start with Newspaper theme is by installing a demo and editing it the way you want: https://forum.tagdiv.com/installing-demos/
