Hi i want to ask how i can on number one on my image to have pinned the video that i want
and why on 2 there is an empty space
my site is here https://top-channel.gr/
Thanks in advance
Using our theme if you want to set some pinned posts, then you’ll need to set the post id, those can be set using tagDiv Composer -> https://forum.tagdiv.com/tagdiv-composer-tutorial-2/ -> https://prnt.sc/26cc1v7
For the block with 4 posts, whet you need to do is to change the posts limit from 4 to 6 -> https://i.imgur.com/LWBveTp.jpg
I hope this will help you!
