Homepage problem
Hi, I have problem to set my homepage with visual composer. What’s I am missing it? Thanks
Check this images :
HI
The layout is affected becasue you’re using a row in row configuration in Visual Composer: http://screencast.com/t/IYlOTgoD0 Try to create your homepage like here: http://screencast.com/t/Zaa7N3SWqBR9 and check how it goes. For more details about how to create your homepage and how to use Visual Composer please check our documentation: https://forum.tagdiv.com/newsmag-homepage-how-to-build-and-set-it/ – https://forum.tagdiv.com/newsmag-how-to-use-visual-composer/
Let us know if you need further assistance on this.
Thanks, problem solve. Good Support
