Hey I’m having problems with my website menu header and footer. I was wondering if there is a way to disable the sticky menu, and my footer has the site logo in it for some reason and I cant seem to find a way to remove it or even put stuff in the footer itself. If anyone can help, please.
Hello NerdOmegaPrime,
If you want to disable the sticky menu, notice that you can do it from Theme panel. For more information about this feature, please consult here -> https://forum.tagdiv.com/newsmag-main-menu/
If you want more assistance with your problem, provide your website URL so I can inspect it closer and also, you can provide some useful screenshots where you should show where exactly the problem is.
