How can I edit the each contents of posts after adopting Post Templates?
I created custom post template with TD composer and applied it to multiple posts and after that,
how can I edit the each contents of posts?
The changes I edited on one post are automatically applied to all posts and I can’t edit individually.
What I would like to do is as following, use one template and change the contents for each articles.
POST:A / TEMPLATE:A / CONTENTS:A
POST:B / TEMPLATE:A / CONTENTS:B
POST:C / TEMPLATE:A / CONTENTS:C
Thanks,
Hello !
Please note that you will have to use multiple post templates if you want to have different layouts on different posts. Find out more about it here: https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
You can set a global template if you want as you can see here: https://www.youtube.com/watch?v=fa7GenCHcBU&t=2s
Thank you for your advice.
I have read the tutorial and tried but it still hasn’t work for me.
I could edit the template of post just as the tutorial but I would like to write(edit) the article, not template.
Is there any tutorial to write article with Tag div Composer after adopting its template?
I tried to edit the article as following but I could only edit its template.
“post” ⇒ “preview” ⇒ “Edit with Tag div Composer”
Thank you for your support.
Hello !
Please note that Newspaper Theme and tagDiv plugins do not offer post editing options. You can only edit the Post Template, not the Post Content.
Please let me make sure.
After set up the post template with Tag div Composer, I need to use WordPress default editor to write the Post Content. Is my understanding right?
Hello !
Yes, In any wordpress setup you have the following:
Post Content ( which is created using Gutenberg or Classic editor usually )
Post Template ( The aesthetics of your post layout. It includes blocks, different styling elements, etc )
You can see here some examples of post templates and how they work here: https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
I hope this was helpful !
