Hi!
I can´t put same structure than demo Newsmag. Why?
I am not sure what you mean, please provide more details about your issue and your site url if possible.
Meanwhile you can check our documentation, maybe will help: https://forum.tagdiv.com/newsmag-newsmag-documentation/ – https://forum.tagdiv.com/newsmag-homepage-how-to-build-and-set-it/ – https://forum.tagdiv.com/newsmag-how-to-use-visual-composer/ Also we have a youtube channel with videos meant to help peoples to understand as easy as possible our theme: https://www.youtube.com/watch?v=TUdVeZ1pbuc&list=PL6CsDkMaejhpWFcFNOIDfdp5nIT0NbUbj
Andrei L..
Hi Andrei ,
I mean how I can make my page, which is this , http://www.pozoblancoradio.com look like here , http://demo.tagdiv.com/newsmag/
As much as I looked I have not seen any configuration that makes it appear so .
First of all your site is set to display the latest article not a static page. If you want to change that go at Settings > Readings and chose a static page to be displayed as front page: http://screencast.com/t/VSDcbdz7tP If you want to change the post template for the blog page, that can be done from theme panel > template settings: http://screencast.com/t/4p9bgL2DAS
Hope this help.
You know how I can put different news in Big Grid and Block 1 ?
Because I get the same in both .
To avoid duplication you can enable Unique Article option: http://screencast.com/t/mhDGQxpLOREB or you can set an offset for block 1: http://screencast.com/t/XDCMLVdUpJK Basically by setting an offset the theme will ignore the first x post corresponding with the filters for that block and will display post from x+1.
Hope this help.
