How can i Set arrow to left and right on Big Grid 2 bottom slide for mobile view
Hi Team,
Let me know how can I set the arrow on Big Grid 2 for the mobile view. In the mobile view it is difficult to understand if tiles are scrollable…maybe add arrows or something to actions scroll.
The theme do not has any arrows to change the posts from Big Grid 2 on mobile, to change it you’ll need to slide to left and right, this can be easy identify because the next post is already displaying on 12-20% from mobile width.
Let me know how can I change the setting for the mobile menu, I didn’t find settings for the mobile menu in the Theme panel. Take a look on this screenshot http://prnt.sc/spu891 I want social icons at the bottom of the menu and also want to show logo at the top of menu.
Unfortunately there is no option to can achieve that, the socials can be set with a custom css, but for logo is no option do do it.
The mobile menu can be set for responsive version from here -> https://i.imgur.com/AZyIDTi.png , if you are using a PRO Demo with tagDiv Composer -> https://i.imgur.com/zy5fzLK.png or if you are using the mobile theme plugin -> https://i.imgur.com/uoesamG.png
I can’t found anything like https://i.imgur.com/AZyIDTi.png on my menu dashboard as you can see http://prnt.sc/sqhqyh
I’m not using the mobile theme.
That option appear only if you are using the mobile theme plugin, if you are not using it, then you need to use a cloud header or a pro demo to can change the menu for mobile (this will be done using tagDiv Composer) -> https://imgur.com/zy5fzLK
