How do I have more than one rating system on a page
I want to have a bunch of rating systems on a page, I only can have one. Thanks
Hello Goomba,
Unfortunately, our theme does not have any such an option that allows you to have a bunch of rating on your page, sorry! Our single rating system is designed to be used for posts and the review can be only made by the author and not the users, sorry! If you want to have another function, in this case, notice that you should try using such a plugin with this functionality and check how it will work for you. Otherwise, please consider hiring a freelancer/developer to help you to implement this, because we cannot provide custom services at the moment, sorry!
For more information about our review system, please check the next documentation here -> https://forum.tagdiv.com/reviews-2/
