How to add custom buttons on front page blocks?
I’ve two questions.
1. How to add custom buttons on front page blocks as needed? https://prnt.sc/gjdl4j I need a link through which user can go to post’s category page (archive page).
2. How can I filter post according to most viewed post on MOST POPULAR section? I’ve checked all the options but there is no option as: most viewed post. I also want to know How is the popular post set?
1) I think you are referring to the ajax filters. Please read this guide: https://forum.tagdiv.com/block-settings-tutorial/
2) The most popular post filter will need the post views to be active. The post with the most views will be the most popular one. You can filter any at all block by popular posts but again, you need to have post views active in the theme panel-> post settings.
Hi, the second one is solved but the first one is still not done yet. I’ve gone through the url. But I specifically want to add VIEW ALL buttons to all blocks of front page to view all the posts to it’s category. https://prnt.sc/gjdl4j Can you please guide me?
You can add an ajax filter to all of your blocks on the front page. edit each one in the tagdiv composer and enable the ajax filter for each one.
I can’t do it. Please guide me step wise to get like this: https://prnt.sc/gjdl4j
I have gone through what you suggested. While enabling ajax filter, I can’t get the option as I want. I just need to VIEW ALL button. This is what I get: https://prnt.sc/gnvan6
Thank You
Thank You
You can change the block header style. This block header style provides a button that directs to the category page used in the filtering on the block
https://www.screencast.com/t/eUVG7CeABKjA
https://www.screencast.com/t/HGtywXB2wPe
These are the currently available block header styles, some display the ajax filter differently as it can be seen
https://demo.tagdiv.com/newspaper/block-header-1/
Thanks Simion C. It worked.
