Hello, because it’s not supported by theme, where I can add code to get excerpt?
Here is pic explanation: https://imgur.com/oeglAvf
Hello !
Please note that your request is custom work based and it is not covered by the support team. You will have to look for the file you need to edit and edit it: https://forum.tagdiv.com/newspaper-theme-support/
