How to add links to the element of top header or footer
For me your website is displaying normal -> http://prntscr.com/pt3712
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
The problem is solved, I wanna ask about inline ads setting, I wrote “AFTER PARAGRAPH:” is 2 this should show an ad after two-paragraph? What If I formatted the paragraph as H3 or H4 tag the ad will show also or not? because I see in some posts there’s one ad only
https://i.imgur.com/HDAvnb7.png
  • This reply was modified 7 years by MML. Reason: some corrections
The inline ad will be display only once after the number of paragraphs you set in theme panel ( this will count only the paragraphs ).
I received an email about the new update 10.2, I need help How to update it, thanks
First please make a full update to your website, after that you can make the update using our guide from here -> https://tagdiv.com/update-newspaper-theme/
Hope this will help you!
Viewing 5 posts - 26 through 30 (of 30 total)
