That is the footer menu, you’ll need to go in Appearance> Menu and set there the menu that you want to show in footer-> http://prntscr.com/pbbd9w -> http://prntscr.com/pbbdtx or if you have set a page as footer page -> http://prntscr.com/pbbedi, you’ll need to edit it with tagDiv Composer.
Thanks for replay,
I have an other error with weather widget, the weather city is disappeared from the top and I searched about How to back it and I found this tutorial but unfortunately I got this error
In order to use the weather widget you’ll need to create an account on https://openweathermap.org/ and get from here a key location that need to be set in theme panel -> http://prntscr.com/pblfke
This setting can be made in theme panel -> http://prntscr.com/pbqohg you can check more in our documentation for Footer templates -> https://forum.tagdiv.com/footer-templates/
The site title can be change from Settings> General -> https://www.screencast.com/t/vo5L0B13p
Hello Calin,
the name in General section is “Viral Feed” did not change, I have successfully changed it from Pages > Front Page, Is there’s a problem with this method?
also, I want to ask about how Can I change the element of “Latest aricle” on the main page,
I tried from the front page but when I click on it nothing appeared on the TD tagDiv Composer!
No, there should be no problem.
If that ” LATEST ARTICLE ” comes from the page template -> than can be change from page backend -> https://www.screencast.com/t/xgCXTll0wRn
Also you can change the “Latest Article” from Theme panel translations ( this will work only if you do not have any text set in latest articles title ) -> https://www.screencast.com/t/HHSIjsak
-> https://www.screencast.com/t/BBRAQPvo
The page template is not in tagDiv Cloud Library, this option is on page -> http://prntscr.com/pd792c you can check more in our documentation from here -> https://forum.tagdiv.com/page-templates-2/
These can be remove if you remove the social networks from theme panel -> http://prntscr.com/phrs0j
You’ll need to create/get a page for 404 from tagDiv Cloud Library and set it in theme panel http://prntscr.com/pjwm9j
I think that you’ve solved the problem, from what I can see -> https://www.screencast.com/t/Ai29wxc3ek now the links are working normal.
From what I can see now the problem is gone -> http://prntscr.com/psnhjl please make sure that you set the CDN as in our guide from here .
Also I saw that you have set and image that do not longer exist -> http://prntscr.com/psnil6
I think that you’ve made something because now the footer image is displaying -> http://prntscr.com/pss3xg
