How to change Widget color in footers
As in screenshot in this I want to change black footer 1, 2 & 3 colors but couldn’t as well as block layout.
https://i.imgur.com/bP7eobP.png
Hello suraj1kc,
Those footer templates are custom made -> https://forum.tagdiv.com/footer-templates/ and all of these can be customized only through the code. Another alternative for you would be to use a Footer Page functionality. You should create a simple page and then set ut it as Footer Page from here -> https://www.screencast.com/t/VqdvPs7ePyv Using this functionality, notice that page can be created with TD Composer and the good part is that you can customize each element as you wish.
Hope this helps!
