How to create a posts loop with specific post IDs?
How to create a post loops with specific post IDs?
Is it possible?
Hello @origamix !
The Posts Loop element automatically filters the posts depending on the tagDiv Cloud Library template you set. As an example, if you’re editing a specific category page, the element will display posted posts from that particular category. Documentation here: https://forum.tagdiv.com/posts-loop/
