how to create different horizontal blocks as per categories?
I have installed the Newspaper theme successfully. Now i want to customize it, what I want to do is create horizontal blocks of particular categories like How to, Apps, etc. How many blocks i can add in the homepage?
Thank you for choosing our theme. I will do my best to help you with your questions.
There are multiple types of blocks and grids provided by the theme. There is quite a variety of blocks designed by us that can be imported with the cloud library plugin
– https://cloud.tagdiv.com/#/load/Blocks
Here is some more information about the cloud plugin – https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
Those blocks are based on the flex blocks and grids available in the composer
– http://prntscr.com/oldw8m
So for example if you wish to use one you can load it directly while editing a page in the composer – http://prntscr.com/oldyjh – http://prntscr.com/oldyto
There are also predefined blocks, grids and full grids
– https://demo.tagdiv.com/newspaper/block-1/
– https://demo.tagdiv.com/newspaper/big-grid-1/
– https://demo.tagdiv.com/newspaper/full-big-grid-1/
Their layout is predefined and they don’t have as many settings as the flex elements.
You can add as many of them as necessary in any page. There is no limit for how many elements can be placed in a page.
Please let me know if you have more questions.
