Hey There,
I am looking to create 2 zones on the front page of the website for example 1st one on the top called “Exclusive” which contain my selected stories in it, same underneath 2nd called “Important” where I will manage some specific stories to it.
Now I want this to be happen from back-end while creating a post there should be a checkbox for both zones “Exclusive”, “Important” when I check the box for any of these the post will straight go to the checked zone on front page. I used zoninator (Zone manager) but this only works for sidebar (widgets).
How is it possible?
Looking for your response.
Unfortunately our theme do not have this option, you can use something similar by using the category posts and assign the post to this category, also on homepage you can use the tagDiv Composer and add some flex block whet you can filter all the categories and show only the one that you want.
Unfortunately we didn’t tested the Zone manager with our theme, therefore we can not say if this will work or not with our theme.
Okay secondly, I am using Guest Author, I have many authors who send me their posts in email and I publish them when I add a guest author it shows at the the single post page but not on the front page and sidebars how can I fix that?
So for the first problem maybe you can use tagDiv Composer and set some flex block where you can display the post you want, maybe this will help you!
For the second problem, the Guest Author was not tested with our theme, therefore we can not say if this will work or not correctly with our theme, sorry! if you want you can check our documentation for adding multiple authors to your articles -> https://forum.tagdiv.com/adding-multiple-authors-articles/ please notice that this will
work only with standard post templates.
