How to design seperate homepage for mobile devices?
We have developed most of the pages on our site with cloud templates. These pages, which look exactly the way we want in the desktop version, unfortunately do not look good on mobile devices.
While we design these pages with tagDiv composer, we cannot design the mobile version of the same page separately.
Question: How can we use the mobile version of the homepage and other pages in a different visual without using the “tagDiv mobile theme” plugin? How can we do this, at least for the home page? We can design a separate home page for mobile only, but how do we ensure that this page is fetched on a mobile device when accessing our site from a mobile device?
Of course, the most useful thing would be to add a feature to the tagDiv composer that can design the same page separately for mobile devices.
Thank you in advance for your interest and help.
Regards.
  • This topic was modified 6 years by Demir.
Hello !
The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
You will have to recreate your pages into the Mobile editor or completely disable the mobile theme. The mobile editor will not render shortcodes !
Thanks for your info Vlad!
We know all your suggestions. We also know that when we activate the mobile theme, a lot of flexibility for the design of mobile pages disappears. As we know these, we do not want to use the Mobile theme.
We want to design a different homepage for use on mobile devices using tagDiv composer. We will not change the home page running on the desktop. However, when our site is requested to be viewed from mobile devices, we don’t know what we should do in order to display a different home page designed for mobile. It will probably be necessary to write a small piece of code for this. If we can get the answer to this question, we can apply this method for other pages besides the home page.
I hope we explained it right.
  • This reply was modified 6 years by Demir.
Hello !
Unfortunately this option is not yet available in Newspaper Theme.
We are sorry for the inconvenience !
