@OnlineThemes Try it again and be sure to follow the instructions carefully. 1.7 is the latest version (and the version that introduced lazy loading) and it works perfect on 1.7. Tested & verified.
User error, conflicts caused by additional custom modifications, and other unrelated code/theme errors are the options for why this didn’t work.
Good luck.
@OnlineThemes In this update 1.7.1 we added an option in Theme Panel to disable lazy loads – http://screencast.com/t/5raycVBjGyIt
Hi Guys, i hacve updated my theme to 1.7.1 but the option to disable lazy load not appearing for me
http://screencast.com/t/LRzNdKIieRRy
anyone know what can be the reason?:
@jk Please make sure that you update your theme properly using this guide via FTP: https://forum.tagdiv.com/how-to-update-theme/
There is an option for this in Theme Panel like I said above.
