How to display and edit "Subtitle" CPT with tadgiv composer?
I wonder, how can I display in front-end the option for the user to add a “Subtitle” text: https://imgur.com/81DIDo2?
Thanks in advance
Also realted, what about the rest of the fields (image on my initial post)? How can I display them and make them possible for the user to add/edit in front-end?
I believe you are referring to how you create a frontend submission form, for this please check our guide – https://forum.tagdiv.com/create-frontend-submission-form/
For the moment only those elements https://i.imgur.com/PLdPOSf.png are in tagDiv Composer, but you can use custom fields to set more. (Unfortunately, the Subtitle element was not added in composer).
There is no way for me to set a custom text field in front-end and the value added in that field would be saved into the subtitle Newspaper theme field?
Something like that can be done, but the text will not be saved in the subtitle, will be in that custom text field that you’ll be adding, but this should not be a problem.
Thanks 🙂
