How to enable tagDiv Composer for Posts
I’m able to see the tagDiv Composer button for Page types but when I go to Post types the tagDiv Composer button disappears where it would display for Page types.
is TD composer only available for pages?
The composer can be used for pages and for cloud templates. Now there are cloud templates for most wordpress templates: post, category, author, tag, archive, search etc.
Here you can see the cloud templates designed by us
– https://cloud.tagdiv.com/
These can be imported with the cloud library plugin
– https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
Once you create or import a cloud post template and apply it, you can use the edit template button in the admin bar. The default post templates can’t be edited with the composer.
So for example if you would like to use a cloud post template, first import one, or create a new one entirely using a blank template – http://prntscr.com/o7rlbz
Then set it for the posts you want.
Let us know if you have more questions.
